Export many tags value to excel.
Jose Ramos
May 2016
Reynosa
I have a trouble with FactoryTalk View Studio because I need export 500 values, I thought in use a for statment and a array because when I try put all the declaration show me a message that say "procedure too large", below you can see the script:
Dim WithEvents MyTagGroup As TagGroup
Private Sub Button7_Released()
Dim MyExcel As Excel.Application
Dim MySheet As Excel.Worksheet
Dim x as integer
Dim mytagvalue as variant
x=2
Set MyExcel = CreateObject("Excel.Application")
MyExcel.Visible = True
'Abrir un Archivo existente
MyExcel.Workbooks.Open "C:\Users\Documents\Cycle TimeCycle_Time.xls"
Set MySheet = MyExcel.ActiveSheet
Dim Tag1 As Tag
For i = 0 to 500
Set MyTagGroup = Application.CreateTagGroup(Me.AreaName)
MyTagGroup.Add "[PLC_10]PalletTime"
MyTagGroup.Active = True
Set Tag1 = MyTagGroup.Item("[PLC_10]PalletTime")
mytagvalue=Tag1.Value
MySheet.Cells(x, 2) = mytagvalue.value
x=x + 1
Next i
'Guardar Ejecucion en un archivo diferente
MyExcel.ActiveWorkbook.SaveAs "C:\Users\demak\Documents\Cycle Time\Cycle_Time" & "-" & Format(Now, "dd-mmm-yyyy-hh-mm-ss") & ".xls"
MyExcel.ActiveWorkbook.Close
MyExcel.Quit
End Sub
Really I need support because I'm new in factorytalk VBA.
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export...
128
Hello, Does anyone know how to export the EDD files for a device in DeltaV Explorer 12.3? I can export the .fhx, but I have no idea how to get...
136
Hi, I'm trying to export data from a DataGrid to Excel using VBA, but I'm getting an error "Object doesn't support this property or method". The...
86
Hello to all, Is it possible to export Codesys symbols to .txt, .csv or .xml in a similar manner like exporting symbol table in STEP 7? For...
135
Good morning, I have a Emerson/GE PLC with Cimplicity SCADA. I need to export data of a specific point/object to a CSV file and load the CSV file...
290
