extention of 6ES5734-1BD20 TTY/RS232 converter cable
tulip
Oct 2005
ist
236
We are using 6ES5734-1BD20 TTY/RS232 converter cable for communication between S5-115U and OP77 Panel.This converter cable max.length is 3.2m and now we want extend the distance nearly 30 m. between Plc and OP.I looked Siemens site there is a information.
in www.elv.de order no: 68-176-10 (for a mx.distance 1000m TTY/RS232 converter) but ''The article you requested is no longer in our assortment ''message is shown.Is there any solution for this? Thanks in advance...
Siemens :
http://support.automation.siemens.com/ww/llisapi.dll?func=cslib.csinfo&objId=23522061&load=treecontent&lang=en&siteid=cseus&aktprim=0&objaction=csview&extranet=standard&viewreg=WW
We once had a similar problem.
We didn't take a Siemens extension cable.
We chose to use a Phoenix Contact module. PSM-ME-RS232/TTY-P
We placed the module close to the panel and then ran a 35m shielded twisted pair cable to the PLC.
Connectors were selfmade with Phoenix contact connectors. 9 pin and 15 pin.
I can't find the pin-outs we used since the setup has been removed over 6 years ago. But I'm sure they can be found on the internet.
I'm not a Siemens guy but here's my take on it
-quote from linked page above-
Instructions:
SIMATIC HMI Windows-based panels do not possess a TTY (20mA) interface which is needed for communication with a SIMATIC S5 PLC.
Exception:
The MP 370 operator panel possesses a TTY interface. Furthermore, the interface can be switched between V24 and TTY on a panel PC in the BIOS.
-end quote-
V24 means RS-232 (comes from the ISO2110 standard V.24)
The TTY they are referring to is also called "Current Loop", not to be confused with an analog 4-20mA current loop.
A TTY current loop drives current signal much longer distances, l000m, but an RS-232 voltage signal is limited to about 15m.
TTY-RS-232 converters convert from a voltage RS-232 to a current loop signal.
Sometimes they're used in pairs when two RS-232 devices are a long distance apart, with one converter at each end, using the RS-232 port on the device but communicating over the long distance with the current loop.
If either the S5-115U and OP77 have a port that can be configured for TTY current loop, then a single TTY/RS-232 converter will work.
If neither the S5-115U nor the OP77 have TTY, then using a pair of current loop converters will work, with the current loop carrying the signal over the long distance.
Hi I am using Simatic field PG M4 with its original RAM (4GB 2RX8). I wish to increase its RAM using addition RAM and ordered one unit...
1,466
Hi, I have OMRON PLC type CPU C500HS. At the moment for troubleshooting I need more time to solve it because the location of the CPU unit inside...
2,601
Hello I have a question about communication plc with profibus. what tools we have need if we want to have 2 nodes (slaves) with cpu315-2Dp...
1,886
I was wondering how can I read a .RSS extention. What program do I need to read it? I the any particular way I should save it? thanks
2,895
I have added an extention block to my Mitsubishi FXon 24mr-es it is a 40er-es. It has 3 lines of inputs 0-7 and 2 lines of outputs 0-7 How would I...
2,594
