extention com module for omron c500HS
indra
Apr 2005
indonesia
161
I have OMRON PLC type CPU C500HS.
At the moment for troubleshooting I need more time to solve it because the location of the CPU unit inside the CONTROL ROOM and the distance between control room and machine is about 50 meter.
So, does any one knows about the EXTENTION COMMUNICATION MODULE that I can use for connecting to the RS232 port in CPU OMRON with such as ethernet cable goes to the near of machine.
With this ethernet cable or extention cable I can make online via this cable and directly FACING THE MACHINE, no need goes to the control room and go out again to check the object in the machine, it takes a long time.
If om ron has this extention module, such as ETHERNET or RS232 repeter, please inform me the model of it.
indra
Hi I am using Simatic field PG M4 with its original RAM (4GB 2RX8). I wish to increase its RAM using addition RAM and ordered one unit...
1,471
We are using 6ES5734-1BD20 TTY/RS232 converter cable for communication between S5-115U and OP77 Panel.This converter cable max.length is 3.2m and...
5,452
Hello I have a question about communication plc with profibus. what tools we have need if we want to have 2 nodes (slaves) with cpu315-2Dp...
1,888
I was wondering how can I read a .RSS extention. What program do I need to read it? I the any particular way I should save it? thanks
2,896
I have added an extention block to my Mitsubishi FXon 24mr-es it is a 40er-es. It has 3 lines of inputs 0-7 and 2 lines of outputs 0-7 How would I...
2,595
