External ENCODER signal can give to s7 1200 plc
Mar 2012
bangalore
19
can give EXTERNAL ABSOLUTE ROTARY ENCODER signal to S7 1200 Plc without SMC(sensor module cabinet)....why?
AND
can give EXTERNAL ABSOLUTE ROTARY ENCODER signal to SERVO DRIVE Double MOTOR Module without SMC(sensor module cabinet)....why?
thank u.....
Reading the other posts from janardhan26reddy I get the impression he's trying to let us do his homework. Maybe that's the reason for the "why". Could be a language issue also, but most people from India I worked with did speak relatively good English.
Kind regards,
can give EXTERNAL ABSOLUTE ROTARY ENCODER signal to S7 1200 Plc without SMC(sensor module cabinet)....?
AND
can give EXTERNAL ABSOLUTE ROTARY ENCODER signal to SERVO DRIVE Double MOTOR Module without SMC(sensor module cabinet)...?
thank u....
external absolute encoders can be directly connected to inputs -
BUT
It is extremely slow and a hell of a lot of programming.
the wiring and control for absolute encoders needs to handle the RPM's.
If this 'Sensor Module Cabinet' is designed to use the encoder then it is better to use it.
If external encoder signals directly connect to s7 1200 plc without SMC.......it will become very slow.....for any main reason......
i'm new student to plc.....plz help me
thank you
read the manual regarding scan times of the PLC
and it's associated program instructions
We are revamping an older packaging machine (new plc, new drives). At the end of the machine there is a belt that synchronises with a belt of...
2,818
Hello all, I am using an IFM RM3011 absolute encoder with a S7-1500 PLC. I am using telegram 81 and external encoder technology object. The axis...
2,088
Hello, I am trying to configure a MR J4 servo amp to accept an external encoder input on CN2L port. Nothing appears to be working. Has anyone...
1,726
I have a few questions about Studio5000. 1. Why is my RA folder so big? its well over 100 GB. 2. How do you delete versions or extra files...
284
I am trying to enable an external alarm via computer speakers for Factory Talk Network Distributed Edition. I am using Alarm and Events setup. I...
180
