Extra serial ports for the Micrologix 1400
02js4130
Jun 2014
Wales
38
I have been given the task of creating a system for which i will need 3 Rs232 comms ports and 1 ethernet port.
A few years ago i completed a similar project using the ML1500 and a 1769 Ascii but the PLC memory became scarce and i had to slim down the program and live in hope this will be enough.
I have been looking at the ML1400 but there doesn't seem to be any expansion modules like the 1769-ascii, does anyone know of any 3rd party equipment?
I need to connect a HMI, scale, Barcode scanner and connection to DH485 network for data acquisition.
Jen
If you use a Red Lion HMI, it could bridge all those devices to DH485 and even map data into the ML1400 PLC from any of its serial ports. The CR1000 has 2 serial ports and the CR3000 has 3 or 4 serial ports. Either can do "gateway blocks" where it can move data between any devices on its configured communication channels and manipulate the data to suit the needs of the recipient.
Hello, I have a question on an OCR application I am doing. I am reading in 16 characters that come from a camera into the plc in its input words...
1,280
Hi, I've got a 1769 controller which is talking to various different components on a local network, I want this controller to talk to another AB...
2,827
hi, i try to send barcode to controllogix (it working with freescan with time out but not serial interface control) i can send command on the clv...
1,348
Hello everyone, We have can counting sensors on all our lines, i am sure all of us know why. So, one of our lines has started counting more cans...
3,280
Hi everyone I want to use a PLC EASY822-DC-TC for a project but I need 13 digital outputs and this PLC only has 9 outputs do any of you would be...
1,404
