Ez-touch edit software help not work
mer
Dec 2009
Asheville nc
59
I got an older version of EZ-TOUCH SOFTWARE.. THE SOFTWARE ITS SELF WORKS GREAT! BUT THE HELP SYSTEM DOESN'T WHEN I PUSH HELP IT HAS A POP UP THAT SAYS (THIS IS A OLDER VERSION OF WINDOWS AND IS NOT SUPPORTED BY WINDOWS VISTA)IT ONLY DOES THIS IN HELP ANY UP GRADES FOR THIS PROBLEM..THANK DAVE
Take it easy on the capital letters please. I dont know how to do it because my computer uses Windows XP. Somewhere in the Vista system I would try to set the compatability mode to Windows XP compatability on your older software or put the software on a computer running Windows XP.
Maybe you can upgrade your software. You may also have to upgrade your panel firmware if you do upgrade the software. Info is in the link below.
Here is the link:
http://support.automationdirect.com/products/eztouch.html
I restore a galaxy in another machine via the cab backup, but when I deploy the project in the new station it seems that the text object and some...
1,002
I believe this has been asked before but no replies, can someone help me out? I can't open an intouch applicantion. The application can be found...
10,858
I require remote access to my projects that are away from home. I did some homework and decided that Weintek looked to have a good solution. Set...
173
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
130
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
125
