InTouch Error, Appedit.Lok
echos
Nov 2010
Edmonton
49
I believe this has been asked before but no replies, can someone help me out?
I can't open an intouch applicantion. The application can be found by intouch application manager but when I try to open it a popup error message appears "The same application is being edited in another session. Cannot edit this application." There is no appedit.lok file in the application folder there are however applogic.lbk and and applogic.lgc. Any suggestions?
Are you showing hidden files and folders in your "Folder View" options? I'm not sure but I think appedit.lok is a hidden file...
ETA: This isn't a NAD enabled app is it?
thanks, yea i am showing hidden files, I had this issue a while ago and deleted the file, now I don't know what to do
Strange.. Are you certain that the app you are trying to open within Intouch is in the same folder you're looking at? I've accidentally edited and run backup copies of applications occasionally.
your right, i did a PC search and found it, it was in a different place, thanks for your help. This website is great!
Hi Gents,
i am also facing the same problem with my intouch 10.1
when i tried to open the windows maker it is showing a same message as mentioned above.
any help to get ride of this issue?
Hi all! I'm new with Intouch and System Platform software but I've done plenty PLC programming and SCADA's. I've developed my own graphic's...
558
I found an older thread about fixing this issue, but the link to the technote was dead. I'm running InTouch 2014R2 with SQL 2012. When I try and...
1,305
Hi there, I have a recurring error when trying to import/create a new application using InTouch, 'Unexpected failure (8000ffff) caught at line 939...
3,341
Hello Can you please help in this error meaning USE 5 CPUs S7_400 to wonderware intouch, 9.5 scada using Cp443-1 and usual lan card to the Pc
1,337
Hi to all my Friends, has anyone faced any issue with Assetion error in Intouch? it comes up as "file rdbmisc.cline188" I can open the same...
1,554
