Hi all,
I just finished an EZ Touch program with about a half dozen screens. I have not downloaded it to the panel yet.
I made a final change to the WinPLC that I was using, rebuilt the project to get the new MAP file, and went to open the EZ Touch program with the new MAP file, but found that I can no longer select the EZ touch program.
If I choose "Edit Program Off-Line", then browse to the project directory, select the .EZT file, everything grays out, and I have to re-select the "Edit Program Off-Line", rebrowse to the project directory, select the .EZT file, repeat . . .
I'm using the latest EZ Touch software (3.1-A), this program worked fine last week. Other EZ Touch files open fine. Any ideas what might have caused the file corruption? Any ideas how to get it back?
Thanks,
Marc
PS: I talked to Automation Direct tech support - they had me try a few things (rename / change directory / delete the .ANO file) with no luck, and then asked me to ZIP it and send it to them for them to try a few things. I was just hoping someone here might have had a similar experience and have some idea for me to try.
Thanks,
Marc
