EZAutomation EZ-T8C-F Touch Screen
ksa858
Jul 2014
Danville
84
Is there a way to adjust the sensitivity on the touch cells for this interface? If I use my fingernail or very tip of my finger pressing a button on the screen it functions fine. If I try to use the base of my finger itself it takes quite a lot of pressure to activate the button.
There doesn't seem to be a way to adjust the sensitivity.
You can only use the Touchpad Test feature in the setup menu.
http://store.ezautomation.net/v/vspfiles/Manuals/EZP-PANEL-M.pdf
"To enter Setup Mode from the user program, press on the extreme upper and extreme lower touch cell on the EZTouch Panel touchscreen. On the first Setup Mode Screen, press the COM1 button. From the ASSIGN COM1 screen (shown above), press Computer. You are automatically taken back to the first setup screen. Press the Exit button to return to the user program."
Regards,
One of my plants has an OLD EZAutomation EZ-T6C-FS HMI that is working with a paired Micrologix 1500. Since the 1500 is now obsolete they have...
1,684
I have been using a EZTouch screen (that I love) and an EZAutomation PLC that I am far from being in love with. It is made at the lower end of the...
2,919
I have this EZC-T6C-E touchscreen I have to update. My software (version 6.2) says that it is not compatible with this unit due to old firmware...
1,805
Has anyone tried out these plcs? They seam to be too good to be true. I have used AutomationDirect, Allen-Bradley, Modicon, etc. but these look...
3,119
