EZMarquee only 1 second RPI minimum?!
asdf6
Apr 2018
Vancouver, BC
I am controlling an EZMarquee display (EZMR-2L10C-E) by EZAutomation with a L82 AB PLC over ethernet. According to their installing/setup guide ("Connecting EZ-Marquee to Control or Compact Logix PLC'S"), page 7, the minimum permitted RPI is 1000ms. I called tech support who confirmed this.
What they could not explain to me was how to correctly use the handshaking framework specified in the user manual EZM-MARQUEE-M. The tech support person did not know how this worked. When i asked for someone who does know they hung-up on me.
Has anybody had experience using this handshaking framework with a RPI less than 1000ms?
Were you able to figure this out? I am struggling with the same issue.
I am trying to set up an EZmarqee with a Siemens ET200sp CPU, CM profibus and TIA v13. Using the DPWR communication block, it has an error of...
1,801
Hi everyone! I am having problem to sent message to EZMarquee(LED Display). I have already set up the profibus connection to EZmarquee(b4 bytes...
21
4,181
HI All, I am having a problem to add EZMarquee in my TIA Portal v13 program. In Rslogix 5000, when I add EZmarquee, there will be Marquee:C...
8,152
Hi All, I am trying to set up the data output for EZMarquee models. In Rslogix5000, I could use DTOS(DINT TO STRING) to convert and use...
3,018
Hello I am trying to set up communications with a controllogix PLC and an EZMarquee display. So far I have found a pdf (see attached) that is...
3,749
