Faceplate / Header tabs
BTL5
Nov 2015
Williamsport
I'm using FT View SE for a project for a customer. I have a header that is separate from the main graphics so that the header is easily edited for future additions to the project. The tab system works using memory tags and setting those tags like this: Set hmi_SelectedTab 1. This works fine, except that the customer wants the tabs to changed color when selected but it changes the color on all of the other monitors rather than the current one they are viewing. They have 4 monitors with 4 separate clients running from 2 boxes. I also have a similar issue with my faceplates. Just a basic faceplate using memory tags for the tabs, but if I open more than 1 faceplate and press tab 2, they all change to tab 2. I'm sure I have to ditch the memory tags, just looking for a little bump in the right direction. Thanks
You're using SE distributed, correct? Yeah its a pain that the local tags are NOT local to each client. The tags are common to all clients because they're server based.
One way to do this would be to use VBA to determine which screen is active and use that to animate the tabs.
Hello, Can you help me to find Logix_PIDE Faceplate? Where I can download a library to use with PIDE instruction? I not have Plantpax CPU. Thank...
469
Hello, I'm trying to create a faceplate that features a bar where a real PLC tag is passed through the faceplate interface. I want to check the...
335
Basically, I need the latest version of the Rockwell "PF525_Faceplate_AOI" THe one I have is v1.0 from 2018 I went to the PCDC and typed...
1,572
Hi Guys, Why PIDE Faceplate in FactoryTalk view SE to display question marks for text objects?
623
A Enduser reported a error on the DLR Faceplate in the HMI. The faceplate freezes and network devices cannot be seen (shows a "?" on each device)...
1,146
