Factorytalk 6.0 64 bit to 32 bit?
jasil
Jun 2012
Building
48
Hired on at a new company (cheap) they have a 50/50 mix of 32 bit and 64 bit .mer and apa files. With all kinds of versions 4.0-6.0.
Without delving into that is there a way to convert the 64bit to 32 bit?
I can open and edit all of hte 32 bit files, but none of the 64 bit files that the intgrator said "were all done in 6.0".
I've searced for a few links, but everything seems to be the other way around.
Thanks as usual!!
If it were me, I'd upgrade them all to 64 bit. You can still create older revisions to run on older hardware, but at least you're moving forward with technology and not backward :)
If you absolutely must do this, you could try to create a 32 bit application, and then manually (and explicitly) export everything from the 64 bit app and then import it to the 32 bit app.
No guarantees that this will work though.
But you must do the export / import. The only way to even possibly deal with reconciling the different database formats is to eliminate them and only go through a text based representation like XML.
I keep a 32bit version of Windows 7 installed in a VMware virtual machine just for this reason and do all my FTview programming there. Works well.
Hi I have an old panel builder 32 that I’m replacing for a factory talk me hmi . In the plc for the old panel builder there is a coms bit for the...
82
Good Morning , Since I’m loading a new laptop , what are you doing for the 32 bit FactoryTalk View projects that you run into ? Are you...
3,827
Just FYI. Installed V31 of Logix 5000 and that updated FT to 4.02.00. Turns out this version conflicts with the licensing software Kepware uses...
2,896
I'm working on a number of HMI projects just now using Factorytalk View ME V9 and I've come to map in my I-O onto the status pages of the screen...
3,220
I'm wondering if anyone here is running FactoryTalk View ME version 10 and has tried importing old 32 bit HMI project archive files, say going...
3,598
