Factorytalk Historian data logging Issue
Sep 2016
indore
Hi everyone, i am using factorytalk historian v4.0 since long time,
yesterday after unexpected power shutdown i am unable to get archive values.
following symptoms found on server:
>number or event read and write are not equal
>no archive shows in archive tab but archive present in path
>register archive or create new archive option in shown disabled
Thanks for any advice
I am not an Historian Expert but i've played with Historian a little bit and run system with it (it runs good till now, even there was couple of unexpected shutdowns).
If you don't see archive file in archive tab in SMT it is obvious that create/register or other archive function will be unavailable.
In my experience when i didn't see archive from SMT, there i had connection issues. Check your connection with Historian Server -> security & mappings.
Do you use domain or simply workgroup for Historian users?
I am looking for a historian software to store historical data from PLCs. I am going to test Factorytalk Historian for this purpose but i need to...
4,739
im using FactoryTalk Historian SE 2.0 , i need the collected data to be backed up periodically and automatically to a network hard disk drive ...
3,998
We are a water/wastewater plant, collecting realtime and manually entered data. We have been using FactoryTalk Historian (OSI PI) for real time...
157
Hello Everyone, I want to install and configure factorytalk Historian v6. I'm new to this. Can you kindly share some knowledge on installing...
91
Has anyone successfully migrated an older Proficy/ iFix Historian database into a new FactoryTalk Historian server? Trying to eliminate having two...
1,164
