FactoryTalk Local Directory - Recommendations
daba
Jul 2004
uk
5,401
I look after 3 sites, each has a FactoryTalk View Studio Local Station Client. The 3 clients are similar.
These are written in Version 7, which pre-dates the segregation of the Local Directory.
I now have to provide a PC that I can move around the sites, while I do some maintenance works on the respective PCs. This PC will need all 3 applications on it, ready to run.
In building this PC, and putting all 3 applications on it, I have discovered that the respective User Group names, and the User names, do not match across the three applications. There is a right mixture - some have Capitalised names (Groups and Users), some have Plural (ending in s) group names, and other discrepancies.
Obviously I don't want to have to Restore each application and Local Directory each time I use the PC on the 3 sites.
What, in your opinions, would be the best way out of this...
1. "Merge" the names to all applications....
2. Correct the Group and User names in all 3 applications and re-create the .CLI and .APA files....
I favour no.2
Your thoughts please..
I would go with #1. Get all the accounts created in the same Local Directory. You could even modify Group names to match the proper application. The users never see the group information.
App1_Operators
App2_Operators
etc....
That would save having to restore the directory each time you needed to work on an application.
OG
App1_Operators
App2_Operators
etc....
OG
Hmmm... I was thinking to go the other way, make a clean directory where I've only got two groups "Controllers" and "Operators" with users "controller" and "operator".
If I go with number 1, someone surely is going to question why I have all these groups, just to satisfy all the permutations in the 3 applications....
Controller
Controllers
controller
Operator
Operators
operator
There's no security involved - neither user "operator" or "controller" has a password, but logging in as "controller" (or "Controller" in one of the applications), opens an identical but different main screen with a few more buttons. I didn't program these apps, and it's not the way I would have done it, but that's what I inherited.
Frankly there's no need at all for a login to take place, as user "controller" often logs in as "operator", and vice-versa.
Another difference is that user "Controller" (or "controller") has a "Shutdown" button on the control screen, but that doesn't work anyway, it doesn't shutdown the app, it just requests a new login. The only way to terminate the client app is with Ctrl-Alt-Del. A very poor way IMHO.
Time for a clean-up, and make the systems work.....
Hi, I'm trying to export data from a DataGrid to Excel using VBA, but I'm getting an error "Object doesn't support this property or method". The...
92
Hello everyone, I am having a problem with conversion from RSView32 to FT View SE Local project on version 12.00 (CPR 9 SR 12). Firstly, I have...
1,419
As per title, I am looking for a way to import the design paths for factorytalk studio. I don't have a personal work laptop but use one of 3 or 4...
2,151
I am upgrading one of our sites from Rsview32 to Factorytalk View SE Local Station on Win10 and I have the program all set up and switched over...
4,177
Hello, Does anyone know a Macro command in FactoryTalk View Studio to copy a Datalog database file to a USB drive or some other location? I...
3,698
