FactoryTalk ME Remote Display w/Parameter
jholm90
Mar 2012
Ontario
155
Looking to call a new screen with FactoryTalk ME v12 from the PLC with a remote parameter...
FYI the parameter value is an integer 100..199
I have successfully used the ME MacroTen activeX control to let the PLC know what the parameter value was used to call the display and now I would like the PLC to call another display with a parameter value of it's choosing. (FYI I ended up blinking the enable bit and reading a tag value from the PLC via a parameter, then writing back to the PLC as {#1} by itself did not work)
I do not have any parameter files in this project, it is just one parameter in a list used on the screens {#1}
I have tried Global Connections\Displays "Use Parameter List" as 1, 0, or blinking and nothing seems to grab this tag value from the PLC when issuing a screen control value. I put a literal string tag on the screen referincing the {#1} parameter and it returns: {[PLC]gHMI1.Par1_Control} ; the exact thing I was hoping to get the value of...not the tag name!
Take a look at the control list display selector. Place it on your parameter page and make invisible. It only purpose is to report the Parameter value to the PLC.
Value = PLC Tag
Indicator = parameter
Remote Access = 1
I am trying to use my PLC program to remotely change displays on my Panel view. Technically it works, but it takes about 45 seconds to change the...
1,938
I have a situation where quite a few remote 1734 cards are not showing their input and output tags via Factorytalk when I try to assign tags to...
3,382
I'm trying to develop a program in FactoryTalk View Studio 5.10 for a PanelView Plus 1500. I set up the RIO driver in the Communications tab and...
7,440
Hello, i need to setup a system that can be monitored remotely. i will have a DSL line to a router and need to monitor the Panelview Plus screens...
5,067
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
198
