FactoryTalk ME Touch Screen issue using InTouch INDT156
fulch
Apr 2023
Brisbane
Hi guys
We're in the process of creating a ME runtime to operate on a PC running windows using a InTouch INDT156 touchscreen, and we're having an issue with the touch itself. When we use a mouse, any buttons on the screen are actuated on the press down of the click which is exactly what we are after. However, when using the touchscreen we find that the buttons then only actuate on the release of the touch on the screen. We need to be able to hold a momentary PB down with the touchscreen, but this obviously cannot happen if the button is only pressed when the finger is removed from the screen.
We've tested this on just the PC folders and files, and it does not behave the same way so I'm assuming that it is a setting or something on the rockwell side but I cannot for the life of me find it. Does anyone have any ideas regarding fixing this? Thanks very much in advance, I really appreciate any help anyone can provide!
This is actually a windows issue. The press and hold on a touchscreen is meant to emulate a right click. This forum post describes the exact same behavior you are seeing, with a potential solution. Unfortunately, it doesn't seem like there is an easy fix to this.
I remember running into something like this a couple of years ago on a B&R IPC. As I recall, there was a setting in the touch screen driver utility that allowed a press & hold to work.
Thanks very much for your assistance guys, I'll take a look at the touch screen driver and see if I can see anything (y)
Hello, I have a graphic in FactoryTalk View SE that uses aTOUCH property to set a tag value equal to 1 on release. Im looking to implement that...
4,584
Need some help. I am scratching my head how to achieve Combo Box functionality in Factory Talk ME, V9 using not navigation keys but touch, similar...
2,843
Hi All, I have used InTouch only but new to FactoryTalk SE so few things in InTouch I am looking within FTSE. 1. within InTouch I can...
3,265
I have a control list selector with 50 states. My problem is that it's inconvenient to go through the list by ramping and then landing on the...
8,460
So I have 250 Intouch Screens early version of Intouch ArchestrA. I need to quickly update those screens to FactoryTalk Who has a fast solution...
1,632
