Factorytalk Node/Computer name?
ScottAgropur
Apr 2015
Wisconsin
The following is my platform:
- Factorytalk View SE Local 8.0
- Same App run on 2 different computers
- Would like to only manage 1 app
The following is what I would like to do, can this be done?
- If app is running on X computer, get node/computer name (X) and use as a permissive to allow certain things. i.e. display allowed to open, turn on bit, etc.
TIA
Scott
I believe you can use VBA code to accomplish this, either by computer name or IP address. I'm not well versed in VBA but possibly checking the help file in FTView SE Studio could point you in the right direction.
FYI:
Don't use the computer name to enable or disable functionality.
Use a "FileExists" type method instead. Much more flexible.
I just have a blank "ReportsOn.txt" file that I stuff on a computer that should print reports. If the file isn't there, then it doesn't print.
FYI:
This works awesome and is so simple. Thanks rdrast!
Has anyone found information on using the variable message file? I keep looking for documentation on how to implement the message file name as a...
30
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
219
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
54
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
110
We are a water/wastewater plant, collecting realtime and manually entered data. We have been using FactoryTalk Historian (OSI PI) for real time...
148
