FactoryTalk: Numberic Display to show (s) for seconds
khelza
Sep 2015
Ontario
67
I have a numeric display which currently displays a value (Specified by Connections>Value field)
However I want it to add an "s" or "sec" after the number to show that it's displaying time in seconds... any easy way to do this within the numeric input?
I use a multistate indicator with 2 states. Put a 0 (zero) for the connection. Use only state 0, with something like this: /*N:4 {[PLC]Tag[8,0]} NOFILL DP:1*/ sec. Now the formatting is done by the software, you just need to add the units at the end.
I do something similar but using a Text object.
Stay Away from the "Numeric Displays" at all costs in any flavor of FTView. They aren't flexible, and have very odd formatting issues a lot. Just use text with an embedded variable.
I like the multistate indicator because it gives you the nice 3D border. And since it's a multistate you could use another state to change the background to red in an alarm condition.
I'm with those guys^^
I never use the numeric or string display. Major PITA. I just use text with an embedded tag, or as jkerekes says, a multistate indicator if I want a border/frame/background/animation.
Agreed, numeric displays are confined and have limited flexibility. Embedding variables into text objects works much better, but does require you to make a fixed background if you don't want the background color (width) expanding and contracting with the number of digits displayed during runtime.
Hello all, I'm having trouble opening an application. After clicking open I'm prompted to login and after putting in username & password it...
64
Has anyone found information on using the variable message file? I keep looking for documentation on how to implement the message file name as a...
63
229
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
68
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
123
