FactoryTalk Private Directory error
MartyMaucher
May 2014
Pensacola
91
In FactoryTalk View Studio - View Machine Edition, I get "Failed to open the FactoryTalk Private Directory" error when opening a project. I can open other projects without a problem.
I've looked and found some suggestions, but none have resolved the problem. I ran the ResDir script, the Directory Configuration program from Rockwell, rebooted, re-installed View Studio, but still not opening.
Another suggestion I found is to delete the files in C:\ProgramData\Rockwell\RNAClient, RNAServer, but I can't because it says the file is open but it is not.
Any suggestions?
Ok, got it working. A number of suggestions I had found say to delete the Private Directory, but don't say where it is. Well, this is where it is:
C:\Users\Public\Public Documents\RSView Enterprise\ME\HMI Projects\<name of project>\PrivateDirectory
Deleted that directory and project opens ok.
Yahoo.
This just happened to me today on a project I had worked on quite a bit. Factory Talk View studio had locked up on me and I had to force it closed. When I tried to reopen the application I got the private directory fault.
Thanks for sharing the solution. Worked perfectly.
The bugs in Rockwell garbage just keep getting worse and worse. What complete **** for software. Most of the development time is spent just trying to navigate this kind of buggy trash....
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
197
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
43
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
105
We are a water/wastewater plant, collecting realtime and manually entered data. We have been using FactoryTalk Historian (OSI PI) for real time...
141
Good morning! Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it...
76
