FactoryTalk SE - ComboBox Issue
saeqsae
Jul 2019
Concepcion
45
Hi all, i working with a combo box but i need some help.
Can you tell me please, how is the command to do an action when i click on a option on the combo box? And can i put "parameters" on the combo box? I mean the P-parameters #1, #2, #3, etc...
Thanks in advance
To access the item selected then use
My_Variable = Combobox1.Item
This puts the value of the selected box into your variable.
Not sure if this syntax is correct for FT but should be similar.
Just look up VBA Combobox there is plenty of info out there
Hi all, i need some help with Visual Basics. I never work with VBA before and i need to add a combobox into my application. Some guys told me to...
3,403
Hi For my issue of selecting data I would like to a have ComboBox (drop down). After an hour searching I found where Rockwell hide them...
1,273
Hello all, I'm having trouble opening an application. After clicking open I'm prompted to login and after putting in username & password it...
53
Has anyone found information on using the variable message file? I keep looking for documentation on how to implement the message file name as a...
63
226
