Factorytalk Test Application Only loading half of the screen
null_BROdem
Mar 2022
Pennsylvania
I'm having some trouble running a test application in factorytalk studio. I'm using FT12, my screen resolution is set to 1920x1080, and when i try to run the test application, half of the screen is cut off. Anybody encounter something like this?
The "Resolution" setting is basically the FTView frame into which windows can be displayed. In your case it sounds like it's the full resolution of your monitor.
Is the actual "Display" size also the full 1920x1080 ?
yes, my display size is 1920x1080. i noticed that if i change the display setting on each individual screen from "display type:replace" to "display type: on top", it "fixes" the issue. im not sure why its cutting out the content when i have 1 vs the other.
I'm trying to display a timer's PRE value in seconds. It works when I hit the test display button, but it displays as ?????? on the HMI and also...
1,832
Good Evening , I'm working on a FactoryTalk View ME project and I have my communication path setup with my L33 CompactLogix and when I do the...
2,151
Hey everyone, Ran into a small hiccup while testing a HMI runtime with a bench unit. We're using a MicroLogix 1100 on our bench to test a...
2,804
Good Afternoon , I have a FactoryTalk View application ( ME ), that I am able to "Test" Run the application on FactoryTalk View and it runs...
7,610
I am using FactoryTalk View 8.20. Can I connect to my HMI application with FactoryTalk ViewPoint if I am running a Test Application on a PC? I...
3,795
