FactoryTalk Transaction Manager not triggering
lmichie
Jul 2014
Sydney
I am trying to add some new transactions to an existing working FactoryTalk transaction manager service (V10.20). One is triggered by a bit (bool) and works while the other 2 are triggered by a change in integer. To my eyes they are duplicating the method used on other transactions on the same system but they don't trigger when the value changes. I'm not sure what other info would help diagnose. Any tips/help would be very much appreciated.
Update: After checking, one is working and 1 isn't. This is driving me nuts!!!
More details. They are both reading from the same PLC using 2 instances of a user defined tag in a compactlogix. In essence, the only difference between them is the name of the master tag and the name of the tables which are also identical structure.
Hi to all.!!! Is anyone having Interfacing of Control Logix 5562 & FactoryTalk Transaction Manager relevant documents and how its linked with...
1,944
Hi guys, I've got a problem with FTTM configuration. In the step 3 (define data points) of the configuration checklist, when i select an...
2,202
Hi All, I'll looked through the forum and the vastness of google with little luck (which makes me believe what I'm going to ask is not possible)...
3,641
Hello All This is my first Transaction Manager project. I have a working configuration in Transaction Manager 10.20 that successfully writes...
7,632
I have searched Rockwell web site and knowledge base and can't find an answer to this question. Trying to install the lastest version of FTTM...
5,883
