FactoryTalk v7 project recovery WITHOUT a .apa?
ajmac
Mar 2014
Lincoln
Hi All,
This may be a silly question, I apologies if it is but I have not worked on Factory Talk since back in 2007 when it was RSView and I commissioning an ME project on a PanelViewPlus on an old Gas Turbine.
I have been given a HMI folder on a memory stick and asked to do some mods, it's a FTv7 SE project but it hasn't been archived so there is no .apa file for me to recover the project into Studio from.
Without the .apa am I up the creek?
If you have the runtime file, there is a PDF HERE that gives step by step instructions.
I think that's just for ME. If enabled, you can use the Application Manager to restore directly from a .mer file with ME as long as it's above V6 (I think that's the one. Maybe 5.1)
SE just uses the file folder structure for its projects, and the .apa is basically those folders zipped up with some metadata.
Personally I would try to create a new project in SE while importing with the .sed from the folders you have.
Thanks for that, it works perfectly! I could have got the guy to generate a .apa but the site is on the other side of the world and had already finished for the day, I wanted to do the work and have it in his mail box by tomorrow.
Good morning, I have a project coming up that will require my HMI runtime to toggle from English to Spanish via selector switch. What is the...
466
I have a FTV project that was moved. The person moved the folder for the project and did not create an .apa file. How can I add this project...
1,688
Hello All! Please help me figure out how to use multiple recipes in the same FT project. My cell contains two production lines and I`d like to...
1,314
I have a client's project file that is in FactoryTalk 8.0. We are currently running 10.0 and when I open up the project it wants me to convert...
1,059
I have a computer with a FactoryTalk View SE local project running version 9. I would like to upgrade the project to version 11 as we have...
5,331
