Moving a FactoryTalk View Project
Tweeker
Nov 2007
Smalltown
79
I have a FTV project that was moved. The person moved the folder for the project and did not create an .apa file.
How can I add this project to the list of available projects to open or open it directly from the folder?
The only way to move applications from one machine to another is to either make a APA or a MER (v5 and newer). You can't just copy/paste the directory. The application manager is the only real way to do it.
What he said. If it's a version >5 and you have it loaded into an HMI then you should be able to upload the .mer and convert it back, but there's no clean way to move projects outside the application manager.
If you end up having to re-create the project you should be able to save yourself work by importing a bunch of stuff (images, displays, etc) from the folder you have though.
First, copy the project files to a new temporary location. Then in FT View go create a new application with the same exact name as the project you are copying. Then go to the projects folder where the new project has been created and copy YOUR project files into the new folder, overwriting all of the files and folders.
This is absolutely NOT the right way to do this. But it will work when someone has not done it the proper way. The proper way is to backup the application from the source machine and send that backup file to you. The backup file is a .APA file for ME. For SE, .APA or .APB I think is the new format for SE.
OG
OG
I was thinking about mentioning this, but haven't tried it myself in a while, so I couldn't remember how it would work out.
Our client is using a lot of Trend Objects in a FactoryTalk SE application. We are currently upgrading their server hardware and FactoryTalk SE...
1,174
I've taken a working FTView 7 project from one PC via the achieve method, dropped it onto another PC on the same network that already had a fully...
1,864
I'm a Siemens person, and this is one of my first AB programs. The customer wants everything programmed in Ladder. I have a lot of data (3...
238
Hello, I have a compact Logix plc and I have been task with configuring alarms into our SCADA when an Analog signal stops moving. The analog...
256
Hello, i am a beginner with a Siemens Logo 8 PLC. I would determine the direction of an object if it passes a whole cycle of 2 input sensors. See...
197
