FactoryTalk VantagePoint EMI - Mobile Links Sample
mich281
Dec 2013
Flanders
A client wanted to know certain production data such as: OEE, Part Counts, Certain Events (Time of Occurrence, Duration,...), Machine States,... So I made a FT Metrics Configuration for this production line. To display the reports, for the moment I use Report Expert (because the templates are to use and edit).
I also installed FT VantagePoint EMI, because I wanted to develop a mobile site, so the client could also see certain reports (adapted for mobile use) on the iPhone. Rockwell developed a simple solution for this, free to use for every RA customer. It consists of a PDF (see link) and a few files to insert in the directory C:\inetpub\wwwroot\incuityportal:
http://www.scribd.com/doc/190514607/Mobile-Links-Solution-for-FTVantagePoint-EMI
It's actually a very simple design: you create a folder 'Mobile' under My Enterprise in VantagePoint EMI. You can add subfolders and reports (inside FT VantagePoint EMI) to this folder. After you have done this you can view the "mobile-friendly" page in Internet Explorer ("http://<servername>/VantagePointPortal/mobilelinks.aspx?fqn=<targetfolderFQN>"; with <servername> being the virtual machine I use for my FT Metrics and FT Transaction Manager configuration; and <targetfolderFQN> being "MyEnterpise.Mobile"). However, we have a problem to see this page on the iPhone.
So we actually want to access a web page that uses HTML and Java to call web services that are run on the server. With a Client PC in the network, we normally connect to the virtual machine using a bridged network setting and specifying a certain IP address (all of them in the same IP range, here 192.168.1.x). Does anyone have experience using this solution, or does anyone know how to connect the iPhone to the network with the reports?
Kind regards,
Mich281
Hi: First, my list of software that I actually using in my application. FTView SE 8.3 Network, FT VantagePoint 7.00, SQL Server 2008 R2 x64...
5,933
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
154
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
39
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
102
We are a water/wastewater plant, collecting realtime and manually entered data. We have been using FactoryTalk Historian (OSI PI) for real time...
139
