FactoryTalk View Alarms Bit Array
lillquist
Dec 2017
Denver
I'm having trouble with alarms coming across from a micrologix 1500 to a Panelview plus 6 600.
This is a conversion from a Panelview standard to panelview plus 6.
I'm trying to bring across an array of Bits to trigger type bit.
Panleview Standard Alarm Setup
Panleview Plus 6 Setup, that isn't working
From Panelview Migration Manual 2711P-AP001A-EN-P:
"The number of bits in the array depends on the data type of the tag. Integer data types, for example, return 16 bits per element, while Bit data types return 8 bits per element."
So I have L3 to bring across 24 bits, as the highest bit value I need is 19. With the setup I have now the alarm triggering the alarm popup, the popup is working with the integer, trigger type: value, alarms but not the bit alarm.
Hi guys, I've got problem about my Alarms services (i think), that happen after installed Visual Studio. I did a few things like, Repair : Studio...
143
Hello Everyone, Happy 4th of July to my neighbors! Is there a way to edit Alarms in Excel? The native export is XML, and there is always...
809
Hi guys! I want to read a tag name of hmi tag to create a generic alarm message. Do you know if it's possible to do? I'm using factorytalk view...
714
Doing some consulting work using factorytalk view studio and RSLogix5000. We set up alarms for the system a while ago and they work fine, as do...
3,645
Hi guys i have troubles getting the selected item properties in FTV Alarms and Events. I have this "Alarm and Event Summary" which displays my...
4,435
