anhtuandrg
Dear all,
I have a button in global object, and that button that button use to open a pop-up window and transfer parameter tags to that pop-up. The problem is when a click in 2 objects in main window, there will be 2 windows. Is there anyway to close the first window after the second window showed up. Because I don't want have a distract when the first window disappears, then the second window shows up. I came up with idea that i will Abort the first window after the second window showed up, but 2 windows have the same name in FTView designer. So when I did that, the second window was closed, not the first one. I wonder that if 2 windows have different name.
Can you guys give me some advices?
