Another issue with Global Objects in Factory Talk View 8.0
Description:
Input Parameters on my Global_Object_1 are #1 and #2.
My Input Parameters Value for this case will be:
#1 => motor structure from PLC, for example: Motor[0]
#2 => description for exact motor, for example: Exhaust Fan
To show #2 i use string embedded variable, with literal option to display it.
It works good.
But (always is a but...) when i display new display from my global object with my input paramters value with command:
Display Global_Object_Details /T{#1}, {#2}
it start to be messy.
#2 (in my case: Exhaust Fan) is displaying: "Exhaust Fan".
How to remove apostrophes from it?
From the manual:
How to deal with it?
Description:
It works good.
From the manual:
Select the Literal string option, to show the text string you type in the dialog box, or the
parameter value that replaces the tag placeholder.
The literal string you type (or specify in a parameter file) cannot contain spaces.
