FactoryTalk View ME Trend models
KevinJesse7
Jan 2017
Michigan
Hi Guys,
I am trying to make a variable trend model. Currently my trend model everything works great and now I decided that I want to be able to change the time span of my model. I want to add a tag and be able to input the time span desired. I don't see this option in the properties tab under x-axis. If someone could shine some light on this that would be great.
Thanks,
Kevin
I seem to remember that the trend model only specifies what data and the sample rate. The duration of data is dependent on storage allocated.
You could stack a few different Trends, and use visibility animation to switch between them (fast changes, but will be slow to load that display).
Or, you could create a few copies of the same Trend display each with different time spans. That seems to be the more common way to do it.
FTView 9 has new trend, but I haven't used that yet.
Yes, Geoff, you are right and you can also vary the time span, but you can only type in integers.
Arlen, I am using version 8.2 but that is a good idea. I'll try the visibility feature and see how it works out.
Thanks!
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
147
Looking for an idea what I'm doing wrong here. FactoryTalk View 9.0 and building a runtime for a v5.10 PV+1500. My pens are drawing like I...
7,373
In the supplied project when you install FT SE 9 there is a trend display that has a Create Snapshot button and a edit box for string data I have...
2,510
I use FactoryTalk View SE (Site Edition) Network and I encounter the problem about Historical Trend as follows; After a recent power outage...
5,831
Any thoughts on how to access the scroll property of a trend object at runtime with a tag in ME? The target device is a PView Plus 1000 if it...
2,477
