Factorytalk view receiving email
Davidnes
Aug 2019
Atlanta
Hi, I would like to know if is possible to use keywords from an email to populate fields on fatorytalk view.
Example: An email is received and use 3 keywords that always will be on the emails that I want to use. then send this as a string to populate fields on my HMI.
Hi. I need to create several alarm servers in an application, but first I need to know if there is any impact on communication, or if more...
44
Hello all, I'm having trouble opening an application. After clicking open I'm prompted to login and after putting in username & password it...
80
Has anyone found information on using the variable message file? I keep looking for documentation on how to implement the message file name as a...
67
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
237
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
157
