Factorytalk View Se 9.0 InstantFIZZ Trend
asterof
May 2007
Califonia
554
In the supplied project when you install FT SE 9
there is a trend display that has a Create Snapshot
button and a edit box for string data
I have tried to use that in my application
and have imported the tags required as well as
the DBF and trend templates, but am still unable to
get it to work. Anyone have any ideas what I am missing
Both the button and edit box link to tags and shortcuts in the Fizz project.
Have you changed those links to match what is in your application?
Oh ok, So ::[ShortCut] refers to a RsLinx Enterprise shortcut in this case.
You can either use a device tag referenced through whatever your device shortcut is(you'll have to check this) or create a memory tag and change the path.
so im using rslinx because I have RSLOGIX5000 on the same machine
and I get a access from duel sources if I enable enterprise
I added shortcut to the topic but it is not showing up in the place as indicated above.
"you need to add/make the tags in the tag browser then refresh the folder"
which tags are you refering to, I did add the Dashboard_Trending tags
you also have open the data log folder and set it up, then on the start up folder enable it data logging
In the PLC I created a UDT called PackD
and added three reals
Current_OEE_Quality
Current_OEE_Performance
Current_OEE_Availability
So these tags are now correct in the Dashboard_Trending folder and there is a topic called shortcut, but I am still confused on where this is ,
107
Hi. I need to create several alarm servers in an application, but first I need to know if there is any impact on communication, or if more...
74
Hello all, I'm having trouble opening an application. After clicking open I'm prompted to login and after putting in username & password it...
88
Has anyone found information on using the variable message file? I keep looking for documentation on how to implement the message file name as a...
80
264
