FactoryTalk View SE with Proficy Historian
Gman22
Mar 2012
Vancouver
Hi Everyone,
I have an application where I need to collect data using GE's Proficy(formally Intellusion's) Historian. Now I have to connect to a FactoryTalk View SE HMI. Has anyone done this before? I know OPC will be involved here, what OPC product would you recommend? I have a KepServer Enterprise CD (Ver 4.5 & Ver 5.3) that came with the FactoryTalk software. Is this the OPC server I would install on the FactoryTalk View box (server/workstation) or a separate box?
Thanks.
FTView SE and GE's Proficy(formally Intellusion's) Historian
Hi Im facing to the same problem. Have you found any solution to connect FTView SE and GE's Proficy(formally Intellusion's) Historian.
Be careful about the KEP servwr which you received. There are two types of KEP servers:
1) Customized KEP server developed for Rockwell - it is not full version , there is not implemented all functionality.
2) KEP server which you can download from KEPware pages. In my project Im using the second KEP server and Im 100% satisfied.
Hi Everyone,
Thanks.
Has anyone found information on using the variable message file? I keep looking for documentation on how to implement the message file name as a...
41
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
222
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
143
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
192
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
135
