Factorytalk Visibilty Function
earlgray
May 2016
Michigan
I am working on something for school. I am using FactoryTalk ME.
The customer needs a way to determine if there motors are in manual. As of now, you click the motor image you get a popup with a manual button and right , Left down up. The problem is some people leave the system in manual, which is bad.
I came up with the idea to use visibility by using the same image but different colors to notify the customer. When the motor is in manual the motor image will be a different color.
I tried to using the tag ({Machining_Zone2\M4009_NAME}={#8})which is the pararmeter file that calls Unit[3009]LocalManMode in the plc and also the plc code({::[PLC].Unit[3009]LocalManMode}=1) but it doesn't work .
Hopefully, I was clear in my post.
Hello all, I'm having trouble opening an application. After clicking open I'm prompted to login and after putting in username & password it...
42
Has anyone found information on using the variable message file? I keep looking for documentation on how to implement the message file name as a...
52
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
224
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
65
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
119
