FactoryTalkView- CurrentLanguage to PLC
asteroide
Jul 2010
der
158
Hello Friends
I have 2 languages in my app, en-US, es-MX.
I need to send CurrentLanguage to PLC, I am trying with Macro in Global Connections but without sucess.
I am trying to send the string like "en-US" or "es-MX".
Also I am trying to send a DINT like 0 for english, 1 for spanish, but neither works
These are my expressions:
{[PLC]Current_Language_String}=(CurrentLanguage())
If (CurrentLanguage( ) == "en-US") Then ({[PLC]Current_Language}=0)
Else ({[PLC]Current_Language}=1)
I have tried a lot of combinations but without sucess.
Can you help me?
Thanks in advance
Both work for me, ver 12 FTME.
What part isn't working? Where are you doing the expression evaluation and checking the value of CurrentLanguage()?
Hello
The language changes OK in the panel with Language Switch Button.
I need to let the PLC to know which language is active in the Panel.
Controller Tag: Type
Current_Language_String String
Current_Language DINT
I have FactoryTalk View ME v11
I have a string display in the panel that shows en-US or es-MX according the language selected, but I cant send this to the PLC. I have done many combinations without success.
The syntax is OK in factory, but in the PLC I am not receiving response.
Thanks in advance
You didn't answer the question. Where are you assigning the PLC tag in FTME the value of CurrentLanguage()? Are you using a button script, macro, or ?, because the language switch button doesn't provide a means to assign a tag. The best method is to use a remote macro tied to system/second that assigns CurrentLanguage() to your PLC tag.
I was using a Macro but tied at the same CurrentLanguage(), so It does not work. I did as you said and now it is working.
Thanks a lot
I just converted an existing application from RSView32 to FactoryTalkView SE. In RSView32, the Datalog was made in a *.DBF file. There was...
71
What is the gold standard ( hoping there is one )for converting ME alarms over to SE? I've been using the RA Knowledge Base method of creating a...
739
WOW. This one still has the low resolution graphics from the 1990's at about 10 times the price. just FOUND OUT Automation Direct Brix can Run...
18
3,107
Hi guys, Is it possible to automatically generate PDF Report of Trend and Datalog in FactoryTalk View SE v12? If YES, Please, how?
683
I have 3 groups of users under security settings. i want a button to be visible when group1 or group3 logged in, and invisible when group2 is...
1,273
