Converting Alarms from FactoryTalkView ME to SE
terlizziJ
Sep 2022
Massachusetts
What is the gold standard ( hoping there is one )for converting ME alarms over to SE? I've been using the RA Knowledge Base method of creating a new digital alarm in SE, exporting it to Excel, using that populated template to paste all of my ME alarm data into as instructed and then importing the spreadsheet into the SE alarms server. Errors and the only alarm that does appear sometimes is the one I created to export into excel in the beginning. There has to be a better way, either that RA is leaving all the little important details out of their Knowledgebase solution.
Thanks!!
You may be running afoul of Excel's habit of messing up CSV files. Does it export to CSV or xls? If CSV, open the export file in notepad. Note the location of single quotes, double quotes, etc. Compare the layout to the file you're trying to import because Excel sometimes adds in extra delimiters. When working with CSV files from Red Lion, for example, I often have to open it in notepad (I actually use Notepad++) and fix things before importing.
Is there any quick way of doing this? I have a bunch of ME alarms I have to transfer over to an SE project. I have exported the alarms out of ME...
3,321
Hello everyone, can anyone help me with covert the STL code to ladder. Iam using plc s71200. A %DB1.DBX33.7 // angel of vaccum...
210
Hello PLCs Forum, I am in a bit of a pickle and was hoping someone could offer me some help. I have a .rss file and just need to see the ladder...
123
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
320
Hello, did anybody know, if there exist an converting cable like the1492-CM1746-M01 (for an 1746-IB16 to an 5069-IB16), for an 1746-HSCE to an...
391
