Fanuc I/O NPN - PNP
raymondj
Dec 2010
Southern CA
We are working with aprox ten year old Fanuc M16i bots with RJ3R controllers. Trying to dope out the config of the Robot I/O - the 8 DI and 8 DO that run through the EE connector to the 6th axis. It appears that the DI are PNP (current sinking), and the DO are NPN (current sinking). This seems strange as all other Fanuc I/O (remote A and remote B) that we have seen is PNP for both DI and DO. Anyone know for sure?
Are you referring to the peripheral device IO that use the CRM2A and CRM2B connectors? If so there are jumpers on the process IO board that allow you to switch the inputs/outputs from sourcing 5to sinking and vice versa.
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
115
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
114
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
106
We recently purchased a IC693CPU352 module and it appears the internal time clock is static. I can set the time and date but once set it does not...
174
I have one GE Fanuc IC200PNS002-AC Versamax Network Interface Module and the fault red light is blinking and i have checked in manual it is...
222
