Fanuc M410 i R 30iA - Ethernet No Robot Heartbeat
Rob S.
Sep 2008
Maryland
739
Good Evening ,
I have a Fanuc M 410i R30 iA , that is communicating with a CompactLogix L32. In the CompactLogix program there is a Robot Heartbeat timer . It is timing out causing a communication fault. I am able to ping that IP address fine for the robot . Would you folks know where this heartbeat comes from , and what could cause this communication to fail. It seems like if I am able to ping the robot we should have a clock pulse .
Thanks , I am stuck again .
Apparently it was the door switch at the base of the robot. Never thought that would effect the communication pulse .
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
115
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
114
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
106
We recently purchased a IC693CPU352 module and it appears the internal time clock is static. I can set the time and date but once set it does not...
174
I have one GE Fanuc IC200PNS002-AC Versamax Network Interface Module and the fault red light is blinking and i have checked in manual it is...
221
