Fanuc PLC
Michael750
Sep 2011
Inola
Hello! We have a fanuc 90-30 IC693CPU350 processor we are needing the software to program and troubleshoot anybody know of free software or if we have to purchase it what do we need and where can we get it.
The software is not free, but if you can get a copy of the CD it will run with full functionality for a four-day trial period. Contact your local GE distributor.
It will be a lot easier if you have a backup copy of the program. That will tell what software was used to program it initially. The current software, Proficy Machine Edition can import projects created with earlier software packages (Logicmaster or VersaPro). However, the annotation for that model PLC does not reside on the CPU module. If you pull the program out of the PLC, all you will get is the logic and the addresses. You won't get any comments or other descriptive text, complicating your task of troubleshooting.
Got an old machine with a IC610CPU104 CPU. A bit of research told me this is the same as DL305 so DirectSoft from AutomationDirect should work...
2,088
Dear Everyone I work with PLC GE-Fanuc. But I don't know that "PLC GE-Fanuc (Series 90-30 and VersaMax) can Online Edit Programming while...
3,079
Our PLC output 7 opens a valve to move a cylinder rod. The output turns on every minute. The output is supposed to be ON for 10.56 seconds. But...
2,913
Need to find where to get VersaPro or Proficy software for the GE Fanuc 90-30 PLC.
2,545
Good afternoon all, hope everyone is doing well. Could someone explain the pic attached on the wrt.not instruction? To me, it looks the same as...
2,126
