Field_Tech
Is it possible to transfer a value into a fanuc position register using a Mitsubishi Q00ucpu plc? For example once in a while we have to touch up a position due to part variance, I was wondering if I could set it up to increment an X value through the HMI. Any info would be appreciated or even an example of code if someone has done this in the past.
Thanks!
Thanks!
