FANUC R30-iA E-stop wiring diagram
peelseeds
Mar 2012
Not at your house.
71
I do realize this is a PLC forum, but I was hoping someone on here might be able to help me, or point me in the right direction, responses here are quick and concise - i like that.
hello everyone, Trying to draw up a design in EPlan for the controllers e-stop circuit. I've got a Fanuc cd with me, inside has a folder called: R30iA controller Rev I
inside has an autorun.exe -which doesn't do anything. I read the *.INF and it also opens a welcome.HTM . from this page you can select categories of help for electrical manuals. (i've tried the safety handbook, controller maintenance, i/o unit model A connection and maintenance)but none of these or the remaining manuals seem like its the right one.
my question is, which manual has the wiring information for the E-stop on the robot controller? (R30-iA)
Thanks for reading!
& your time.
Thanks mvaughan.
I believe my question was worded wrong. I needed a diagram of the safety signals the controller uses. I ended up finding a diagram in a Rj3-iB maintenance manual.
thanks and sorry for the confusion.
peelseeds - The manual you want is the Controller Maintenance Manual MARMCIA304071E; Section III. CONNECTIONS; Chapter 3 - Electrical Connections. The diagrams you probably want are on pages 288 and 289.
I am not fond of the way Fanuc is now doing their manuals on the CD which requires you to open each page individually, but it is what it is. Personally, I took the individual PDF pages from the manual and used a third-party software to join them into a single document. Still not as good as it could have been, but much better IMHO.
Steve
Thanks Steve. That was the manual I ended up finding the correct information. allthough not sure if its the same (MARMCIA304071E) but I used a Controller maintenance manual for R-30iA. location you suggested was correct but the pages were 221-225
Wiring Diagrams
I know this was a while ago but I was wondering if anyone has the PDF they can send me, I have the same controller and a robot donated to our school but no documentation was included...this makes it very difficult to wire, any help would be appreciated,
Cheers
Matthew
P.S. has anyone had a broken key switch error?
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
112
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
112
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
104
We recently purchased a IC693CPU352 module and it appears the internal time clock is static. I can set the time and date but once set it does not...
172
I have one GE Fanuc IC200PNS002-AC Versamax Network Interface Module and the fault red light is blinking and i have checked in manual it is...
220
