Fast Pulse Counter, Micro850
Or, if the PLC could drop the speed when it gets close to the target, then no counts would be missed in the main program. But like you say, you got it where you want it.
Thanks!
I cant really control the speed since its pretty much determined by the speed of the engine and hydraulic pump.
What I did do though.... There are 2 solenoid valves for the stroke in and out. I did set up both the stroke in coils on separate outputs, so one drops out 100mm before the other, making it half the amount of hydraulic flow to get stopped when it does reach its target.
Sweet!
Objective : Once the inlet flow drops below the set point on the filter chamber it starts a cleaning sequences and flushes the filter with...
5,071
Hello! I need to know how fast pulse I can get (without any special cards etc.) out of my Siemens 314-1AE02-0AB0? I think the SFB43 is not...
2,105
Hi All, I've been playing with 2 stratix switches in my test bench and seeing how different configurations affect the behaviour when 2 managed...
230
Dear all, Im using Allen Bradley Compact Logix L36ERM as a PLC. and facing a problem where I need to create a FIFO buffer that fills an...
1,660
Dear Members; We have Fluke 754 hart communicator. We have wired up three transmitters of Rosemount Model C3051 with this input module. But when...
1,852
