Fault finding in plc
Avatar_41
Aug 2019
Istanbul
96
Hello guys. There is a fault on the PLC program that comes to the HMI panel via Data Block. This fault prevents the machine from working. Incoming Fault address "DB75.DBX70.3" (Please refer to picture #1)
When I search for the address with the Go To option, nothing comes up.
(Please see picture #2.)
When I enter the Data Block, a single block appears and I open the block with the "Open Block" option.
(Please refer to UDT75.pdf.)
View attachment UDT75.pdf
It contains hundreds of addresses. However, "70.3" is not displayed directly.
When I looked at the HMI program with Wincc Flexible, I could not find anything related to the address "DB75.DBX70.3" in neither the Fault nor the Tags section.
My question 1-) How can I find the address "70.3" directly from hundreds of such addresses in an easy way?
My Question 2-) Why don't I get any results when I use the Go To option with Simatic Manager?
In such cases, what triggers the malfunction, etc. I need to find answers to questions such as, but I can't. I don't know how to do it or I'm making a mistake somewhere.
Without the whole program it is difficult to be certain for your particular problem, but if a UDT is passed as a parameter, the individual addresses in the UDT will not come up in the cross reference.
This is the address that 70.3 refers to:
Hi all, I am just looking for other more experienced opinions on how programmers use simulation to help fault find errors in their PLC program...
2,418
Hi All, I am very to new to PLC and OPC in the production enviroment so please bare with me whilst I try to explain what my issue is. Hopefully...
3,415
Hi all, I've been tasked with finding a glich in a program/programs... A barcode data array is moved through a line where pallet strapping and...
3,764
We have multiple FTView SE (CPR9 SR9) clients and servers on site. On some of the clients "set" commands via buttons are not always registered in...
999
Hi All, I am putting together a "fault finding guide" for some remote sites that i support. Effectively i have stated that there are four...
9,417
