fault reporting by gmr(gefanuc,90-70) system
mvlrao
Aug 2003
DUBAI
i have problem with respect to faults reporting by hblock output group in gmr system(ge-fanuc 90-70)
FAULTS REPORTED BY H BLOCK GROUP:
1.FOR OPEN CIRCUIT FAULT - ALL 4 BLOCKS ARE NOT REPORTING FAULT TO THE CPU(ONE OR TWO OR THREE BLOCKS ARE REPORTING RANDOMLY,IT IS NOT CONSISTENT WITH ANY BLOCK(A/B/C/D)
2.WHEN I/O FAULT RESET IS INITIATED WITH %M12258 ,FAULT STATUS FROM ONE BLOCK IS CHANGING TO ANOTHER BLOCK IN THE GROUP.(THIS IS ALSO NOT CONSISTENT)
pls. let me know the reason/solution)
Are you saying that you have blocks reporting open circuit faults when no faults exist or that blocks fail to report actual open circuit faults? Are the faults on input circuits or output circuits?
You mentioned a gmr redundant system. Is it redundant bus? Redundant blocks? Redundant I/O? These tend to be pretty complex systems. Have you been in contact with the OEM?
gmr-system h block faults
some of the blocks(out of 4 blocks) fail to show actual open circuit faults.
faults are on output circuits. gmr system H block consists of 2 source and 2 sink blocks)
Each individual circuit on a Genius block can be configured whether or not to report open circuit faults. Have you verified that the circuits in question are properly configured? You can check this with your Hand-Held monitor IC660HHM501.
i have problem with respect to faults reporting by hblock output group in gmr system(ge-fanuc 90-70) FAULTS REPORTED BY H BLOCK GROUP: 1.FOR...
5,000
I've been suffering through a problem with the PLC5 power supply "PS 1771-P7 B" shutting down. I say "shutting down" because when I show up at the...
2,218
Hi all, hope somebody can give me a hand with this. I have been asked to implement an extended fault reporting scheme for a 90-70 PLC that I am...
28
7,294
Hi. We've been asked to do an upgrade on plant, consisting on a PLC upgrade. This involves replacing a 1747-SDN module to a 1769-SDN, in a network...
37
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
76
