Jaqson Belnap
Hello,
When I go to Instruction Help for a GSV instruction in Studio 5000, and then scroll down to the bottom of the webpage it directs me to and click the GSV/SSV Objects link, and then click on the Module link on the page it directs me to next, I see that there is a list of links for module faults. When I open one of these links, a table is provided that has columns for Code, String, and Explanation and Possible Causes/Solutions. I do not see a column for FaultInfo. Going back to the page that opens after selecting Instruction Help on a GSV instruction, there is a link on the bottom of the page labeled GSV/SSV Programming Example. When I click on this link, I can see on Example 1 that we would be able to see the FaultCode for the module in disc_in_2_info.FaultCode and we would be able to see the FaultInfo for the module in disc_in_2_info.FaultInfo. By looking at the table I mentioned earlier, I can get an idea of what module fault codes I might see (INT), but how do I know what fault info I might see (DINT), since there is not a column for fault info? Does anyone know of a table that can be referenced in another resource to see what module fault info would be associated with each respective module fault code?
