Locked "history" attribute in wonderware
bigLee
Jun 2018
Florida
77
I am trying to clean up the historian by unhistorizing obsolete objects with history attribute selected.
Many of them are derived from templates and locked down, preventing the attribute from being unchecked. I've unlocked everything I can see on the parent template to no avail.
Anyone have any ideas? Thanks!
The historian is fine. As I'm deleting obsolete tags, I'm unhistorizing object attributes so they don't reappear in historian as they are selected to historize. If they are checked to historize in the parent template, I cannot uncheck the history attribute in the derived templates. I can only uncheck history at parent template level then I have to go through every instance and recheck history on all attributes that need to be historized.
My question is there a way to unlock so it's editable at the derived level without unhistorizing all instances?
If the Historian is "fine", then never mind. After all, I'm sure nothing changed in the versions from 9 years ago. Silly of me to ask which version you were running.
Greetings I have a problem, my system is the following: wincc v8.0 (demo), logo8.3, abb m2m analyzer. I created some pages to display the...
71
I've noticed a strange behavior with certain rotary disconnects. We all know that, if installed correctly, the disconnect interlocks with the door...
1,473
Hello expert, Kindly help me to open/view the locked block in the attached S7-200 backup "Lim_Switches" Thank You.
625
Hi all, I'm experiencing some difficulties changing faceplate values inside the FactoryTalk ME edition with the PlantPAx process library 4.10.06...
1,898
Hi, I have bought a used 1756-L73S and SP, it is running firmware 30.013 and safety locked, im running Logix Designer 30.01.00. The controller...
1,666
