Faultrecord logix5000
Narlin
Mar 2010
phoenix
320
When a major fault occurs with Logix5000, a UDT FAULTRECORD will show the following information when I click on “Go To Faults” .
09/09/2014 08:36:15
(Type 04) Program Fault
(Code 999) User-defined fault.
Fault Information Dump:
Info[0]: MainTask
Info[1]: MainProgram
Info[2]: a01_MainRoutine
Info[3]: Rung 6
Info[4]: 000ee848
Info[5]: 000ee848
Info[6]: 000ee368
Info[7]: 00000000
However, My instance fault record shows numbers
TAG
VALUE
TYPE
STYLE
Major_fault_record.Time_Low
779059123
DINT
DECIMAL
Major_fault_record.Time_High
328353
DINT
DECIMAL
Major_fault_record.Type
INT
DECIMAL
Major_fault_record.Code
999
INT
DECIMAL
Info[0]
DINT
DECIMAL
Info[1]
9248
DINT
DECIMAL
Info[2]
9248
DINT
DECIMAL
Info[3]
975720
DINT
DECIMAL
Info[4]
976968
DINT
DECIMAL
Info[5]
976968
DINT
DECIMAL
Info[6]
976968
DINT
DECIMAL
Info[7]
DINT
DECIMAL
Is there a way to display the data onto an OIT that has information more similar to the 1st listing?
My AB PLC got fault record in CF card.But I dont know how to open it.Could anyone help me?
1,526
Hi All, For some reason, I had to clear the recoverable major error in the fault hander routine and record the fault for history check, The...
3,394
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
152
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
451
I'm a Siemens person, and this is one of my first AB programs. The customer wants everything programmed in Ladder. I have a lot of data (3...
251
