FB10 for FHPP festo
Ironman02
Sep 2018
Tlaxcala
Hi gays,
i hope that you are well,
Somebody help me to undertand what is the meaning about the f10 because i can not to move anymore the servocylinder, I have all the conditions for the drive to be enabled as indicated by the manual but I can not enable it so I wanted to see why it does not allow me or what conditions prevent me from enabling it but when I opened the fb then there I was complicated because I do not understand very well the indirect address,
SET
SAVE
= L 2.1
CLR
= #StrokeLimitReached
= #VelocityLimitReached
= #StateContinuousMode
= #StateControlModeB2
= #StateControlModeB1
L 0
T #ActualRecordNo
= #RC1
= #RCC
T #ActualVelocity
T #ActualForce
T #ActualRotRamp
L L#0
T #ActualPosition
T #ActualRotSpeed
L #I_ADDRESS
T LW 4
L DW#16#10020008
T LD 6
L DINO
T LW 10
TAR2
+ L#432
T LD 12
TAR2 LD 16
UC "DPRD_DAT"
P#L 4.0
P#L 0.0
P#L 6.0
LAR2 LD 16
L #SFC14_15_RET_VAL
A BR
NOT
JCN A7d0
JU A001
A7d0: L #INPUT_DATA.BYTE1
T #_Byte
CLR
A DIX [AR2,P#70.7]
= #StateOperationModeB2
A DIX [AR2,P#70.6]
= #StateOperationModeB1
A DIX [AR2,P#70.5]
= #ControlFCT_HMI
A DIX [AR2,P#70.4]
= #SupplyVoltPresent
A DIX [AR2,P#70.3]
= #Fault
A DIX [AR2,P#70.2]
= #Warning
A DIX [AR2,P#70.1]
= #Ready
A DIX [AR2,P#70.0]
= #DriveEnabled
L #INPUT_DATA.BYTE2
T #_Byte
A DIX [AR2,P#70.7]
= #DriveReferenced
A DIX [AR2,P#70.6]
= #StandStillControl
A DIX [AR2,P#70.5]
= #DragError
A DIX [AR2,P#70.4]
= #DriveMoving
A DIX [AR2,P#70.3]
= #AckTeach
A DIX [AR2,P#70.2]
= #MC
A DIX [AR2,P#70.1]
= #AckStart
A DIX [AR2,P#70.0]
= #HaltNotActive
A #StateOperationModeB1
JCN A7d1
L #INPUT_DATA.BYTE3
T #_Byte
A DIX [AR2,P#70.5]
A DIX [AR2,P#70.4]
A DIX [AR2,P#70.3]
A DIX [AR2,P#70.2]
A DIX [AR2,P#70.1]
JU A7d2
A7d1: L #INPUT_DATA.BYTE3
AD DW#16#FF
T #ActualRecordNo
A7d2: L W#16#0
T #_Word
CLR
= DIX [AR2,P#73.0]
A #StateOperationModeB2
= DIX [AR2,P#73.1]
A #StateControlModeB1
= DIX [AR2,P#73.2]
A #StateControlModeB2
= DIX [AR2,P#73.3]
A #StateContinuousMode
= DIX [AR2,P#73.4]
L #_Word
T #StateOPM
L #StateOPM
L 0
TAK
==I
T LW 4
JC A7d4
JU A7d5
A7d4: L #INPUT_DATA.BYTE4
T #_Byte
CLR
A DIX [AR2,P#70.0]
= #RC1
A DIX [AR2,P#70.1]
= #RCC
A DIX [AR2,P#70.4]
A DIX [AR2,P#70.5]
L #INPUT_DATA.BYTE5_8
T #ActualPosition
JU A7d3
A7d5: L 1
L LW 4
==I
JC A7d6
L 13
TAK
==I
JC A7d6
L 17
TAK
==I
JC A7d6
JU A7d7
A7d6: L #INPUT_DATA.BYTE4
AD DW#16#FF
T #ActualVelocity
T #ActualPosition
JU A7d3
A7d7: L 5
L LW 4
==I
JC A7d8
JU A7d9
A7d8: L #INPUT_DATA.BYTE4
AD DW#16#FF
L 128
>=I
JCN A7da
L #INPUT_DATA.BYTE4
L B#16#FF
XOW
AD DW#16#FF
T #ActualForce
L #ActualForce
L 1
+I
L -1
*I
T #ActualForce
JU A7db
A7da: L #INPUT_DATA.BYTE4
AD DW#16#FF
T #ActualForce
A7db: L #INPUT_DATA.BYTE5_8
T #ActualPosition
JU A7d3
A7d9: L 9
L LW 4
==I
JC A7dc
JU A7d3
A7dc: L #INPUT_DATA.BYTE4
AD DW#16#FF
T #ActualRotRamp
T #ActualRotSpeed
A7d3: L #OPM
T #_Word
CLR
A DIX [AR2,P#73.0]
= #OperationModeB1
A DIX [AR2,P#73.1]
= #OperationModeB2
A DIX [AR2,P#73.2]
= #ControlModeB1
A DIX [AR2,P#73.3]
= #ControlModeB2
A DIX [AR2,P#73.4]
= #ContinuousMode
L B#16#0
T #_Byte
A #OperationModeB2
= DIX [AR2,P#70.7]
A #OperationModeB1
= DIX [AR2,P#70.6]
A #HMIAccessLocked
= DIX [AR2,P#70.5]
CLR
= DIX [AR2,P#70.4]
A #ResetFault
= DIX [AR2,P#70.3]
A #Brake
= DIX [AR2,P#70.2]
A #Stop
= DIX [AR2,P#70.1]
A #EnableDrive
= DIX [AR2,P#70.0]
L #_Byte
T #OUTPUT_DATA.BYTE1
TAK
T #_Byte
CLR
= DIX [AR2,P#70.7]
A #ClearRemPos
= DIX [AR2,P#70.6]
A #TeachActValue
= DIX [AR2,P#70.5]
A #JogNeg
= DIX [AR2,P#70.4]
A #JogPos
= DIX [AR2,P#70.3]
A #StartHoming
= DIX [AR2,P#70.2]
A #StartTask
= DIX [AR2,P#70.1]
A #Halt
= DIX [AR2,P#70.0]
L #_Byte
T #OUTPUT_DATA.BYTE2
A #OperationModeB1
JCN A7de
CLR
= DIX [AR2,P#70.7]
= DIX [AR2,P#70.6]
A #DeactivateStrokeLimit
= DIX [AR2,P#70.5]
CLR
= DIX [AR2,P#70.4]
A #ContinuousMode
= DIX [AR2,P#70.3]
A #ControlModeB2
= DIX [AR2,P#70.2]
A #ControlModeB1
= DIX [AR2,P#70.1]
A #AbsRel
= DIX [AR2,P#70.0]
L #_Byte
T #OUTPUT_DATA.BYTE3
JU A7df
A7de: L #RecordNo
AW W#16#FF
A7df: L #OPM
L 0
TAK
==I
T LW 4
JC A7e1
JU A7e2
A7e1: L B#16#0
T #OUTPUT_DATA.BYTE4
L L#0
T #OUTPUT_DATA.BYTE5_8
JU A7e0
A7e2: L 1
L LW 4
==I
JC A7e3
L 13
TAK
==I
JC A7e3
L 17
TAK
==I
JC A7e3
JU A7e4
A7e3: L #SetValueVelocity
AW W#16#FF
L #SetValuePosition
JU A7e0
A7e4: L 5
L LW 4
==I
JC A7e5
JU A7e6
A7e5: L B#16#0
L #SetValueForce
L 100
>I
JCN A7e7
L L#100
JU A7e0
A7e7: L #SetValueForce
L -100
<I
JCN A7e9
L L#-100
JU A7e0
A7e9: L #SetValueForce
ITD
JU A7e0
A7e6: L 9
L LW 4
==I
JC A7ea
JU A7e0
A7ea: L #SetValueRotRamp
AW W#16#FF
L #SetValueRotSpeed
A7e0: L #O_ADDRESS
T LW 4
L DW#16#10020008
T LD 6
L DINO
T LW 10
TAR2
+ L#496
T LD 12
TAR2 LD 16
UC "DPWR_DAT"
P#L 4.0
P#L 6.0
P#L 0.0
LAR2 LD 16
L #SFC14_15_RET_VAL
A BR
NOT
JCN A7ec
JU A001
A7ec: SET
= L 2.1
L 0
T #RET_VALUE
SAVE
BEU
A001: CLR
= L 2.1
L #SFC14_15_RET_VAL
T #RET_VALUE
SAVE
This looks like an Step 7 Siemens block probably a standard one of theirs, if it is then do not modify it. If it is Step 7 then I suggest this block is not the problem.
CALL "CMMP_AS_CTRL" , "FB10_AUX_DB"
I_ADDRESS :=W#16#100
O_ADDRESS :=W#16#100
EnableDrive :="VERT_CYLINDER_DATA".EnableDrive
Stop :="VERT_CYLINDER_DATA".Stop
Brake :="VERT_CYLINDER_DATA".Brake
ResetFault :="VERT_CYLINDER_DATA".ResetFault
HMIAccessLocked :="VERT_CYLINDER_DATA".HMIAccesslocked
OPM :="VERT_CYLINDER_DATA".OPM
Halt :="VERT_CYLINDER_DATA".Halt
StartTask :="VERT_CYLINDER_DATA".StartTask
StartHoming :="VERT_CYLINDER_DATA".StartHoming
JogPos :="VERT_CYLINDER_DATA".JogPos
JogNeg :="VERT_CYLINDER_DATA".JogNeg
TeachActValue :="VERT_CYLINDER_DATA".TeachActualValue
ClearRemPos :="VERT_CYLINDER_DATA".ClearRemPos
AbsRel :="VERT_CYLINDER_DATA".AbsoluteRelative
RecordNo :="VERT_CYLINDER_DATA".RecordNo
SetValueVelocity :="VERT_CYLINDER_DATA".SetValueVelocity
SetValuePosition :="VERT_CYLINDER_DATA".SetValuePosition
SetValueForceRamp:="VERT_CYLINDER_DATA".SetValueForceRamp
SetValueForce :="VERT_CYLINDER_DATA".SetValueForce
SetValueRotRamp :="VERT_CYLINDER_DATA".SetValueRotRamp
SetValueRotSpeed :="VERT_CYLINDER_DATA".SetValueRotSpeed
DriveEnabled :="VERT_CYLINDER_DATA".DriveEnabled
Ready :="VERT_CYLINDER_DATA".Ready
Warning :="VERT_CYLINDER_DATA".Warning
Fault :="VERT_CYLINDER_DATA".Fault
SupplyVoltPresent:="VERT_CYLINDER_DATA".SupplyVoltageOk
ControlFCT_HMI :="VERT_CYLINDER_DATA".ControlFCT_HMI
StateOPM :="VERT_CYLINDER_DATA".StateOPM
HaltNotActive :="VERT_CYLINDER_DATA".HaltNotActive
AckStart :="VERT_CYLINDER_DATA".AckStart
MC :="VERT_CYLINDER_DATA".MC
AckTeach :="VERT_CYLINDER_DATA".AckTeach
DriveMoving :="VERT_CYLINDER_DATA".DriveMoving
DragError :="VERT_CYLINDER_DATA".DragError
StandStillControl:="VERT_CYLINDER_DATA".StandstillControl
DriveReferenced :="VERT_CYLINDER_DATA".DriveReferenced
ActualRecordNo :="VERT_CYLINDER_DATA".ActualRecordNo
RC1 :="VERT_CYLINDER_DATA".RC1
RCC :="VERT_CYLINDER_DATA".RCC
ActualPosition :="VERT_CYLINDER_DATA".ActualPosition
ActualVelocity :="VERT_CYLINDER_DATA".ActualVelocity
ActualForce :="VERT_CYLINDER_DATA".ActualForce
ActualRotRamp :="VERT_CYLINDER_DATA".ActualRotRamp
ActualRotSpeed :="VERT_CYLINDER_DATA".ActualRotSpeed
RET_VALUE :="VERT_CYLINDER_DATA".RET_VALUE
Hi, This is the original FB but i don't want modify it, i want to understand for give the comand in mode jog because is in extra stroke and i can't move anymore, anybody help me
I need this output but i dont understand how to enable in the fb 10, sombody help me to understand the meaning of the indirect adress,
CLR
= DIX [AR2,P#70.7]
A #ClearRemPos
= DIX [AR2,P#70.6]
A #TeachActValue
= DIX [AR2,P#70.5]
A #JogNeg
= DIX [AR2,P#70.4]
A #JogPos
= DIX [AR2,P#70.3]
A #StartHoming
= DIX [AR2,P#70.2]
A #StartTask
= DIX [AR2,P#70.1]
A #Halt
= DIX [AR2,P#70.0]
L #_Byte
T #OUTPUT_DATA.BYTE
Hi All, I am trying to communicate siemens PLC with FESTO Servo & 3 Festo make Steppers on FHPP Modbus Protocol. Sometimes, I face Modbus...
1,343
Glad the site is working again... I have a customer having issues with a Festo and I have never worked with them, see below
1,331
Working with a Siemens PLC, I have to replace a bad Festo valve bank Profinet adapter with part number: CTEU-PN I am very comfortable with...
1,182
Hello Experts, Does anyone have this gsdml v2.31 festo cteu 20150503?? I've gone to the Festo website and the version that they have for cteu is...
810
Hello everyone, It's the first experience with a Festo's drives and the Festo Configuration Tool programming tool. Particularly with these...
1,517
