FBD to LADDER
mnsaid
Jun 2016
tunis
Hello,
I'm currently working on an automation project with Allen Bradley RSLogix5000, FTView ....
I have a problem with the analog outputs, I have programmed with the feature FBD (Functional Block Diagram) but my license reaches its expiration date so I find myself obliged to reschedule with ladder.
I tried with "cpt" in ladder but I have received nothing as result
explanation of the Example: I have a valve and i need to control it with 0-100% opening range(Input) and analog output 4-20 mA so all what i want is the implementation to scale (scale) so I started with a linear function y = ax + b and I found this final equation Y = 160X + 4000;
remote_6: 14: O: Ch1Data = 160 + 4000 * Pcv4011.Val_Aut
PS: Y is my output (remote_6: 14: O: Ch1Data) , X: the opening desired (0 -> 100) PCV4011.Aut_Man indicates the automatic or manual mode.
I am at your disposal for any further explanation.
the first is programmed with FBD it work correctly but the second dont work.
for exemple for an input 50 the first give us 12000 (12mA) but the second (with ladder) still the same 20000 and does not follow the input.
yes i know that , they have the same I/O but not the same project , i used the FBD in a project and the ladder one in other project and they are not running in the same time.
change your DEST on the Ladder one to a test variable and see if it will work.
It sounds like both of them are writing to the same place and the old one is writing last.
i already did that but it remains the same problem.
in other word how you scale your analog output (4-20 mA) ?
Hello, So in RSLogix 5K I would be used to doing the following: 1. Double click the left of the rung, to bring the rung text editor, will be...
2,106
Good day all. I would like to know if it is possible to change programming languages in RSLogix5000? For example, if a program is written using...
4,852
Is it possible to combine ladder and function block on RSLogix 5000? I can do ladder and FB but I have a code where analog and discrete signals...
2,904
Hi, I want to do this in FBD in Unity PRO... how do I do that??? A B |---...
4,410
My dear fellows... please help the needy guy who want to convert ladder code for start up routine to FBD using some automated tool. Please...
5,002
