Ladder to FBD in UNITY PRO
Marie1982
Feb 2007
House
121
I want to do this in FBD in Unity PRO... how do I do that???
A B
|--- ||-------------------(P)---|
B A
|---||-------------------(R)---|
[EDIT] ok i don't know how to fit the letters above the contacts and coils, but i guess you can figure out what i mean
The reason I want to do this is because A is set by HMI via Modbus command, and I want the PLC to reset the command and use B in my logic.
Thanks.
Marie
Marie1982 said:
A B
B A
Thanks.
Marie
The easiest way would be to create your own FB with that ladder in it, should take about 30 seconds to do.
I found how.
For the first line use the R_TRIG block. A as the input and B as the output.
For the second line use the RS block. Put A for S parameter and B for R parameter and A for the output.
thanks
Hello, So in RSLogix 5K I would be used to doing the following: 1. Double click the left of the rung, to bring the rung text editor, will be...
2,106
Hello, I'm currently working on an automation project with Allen Bradley RSLogix5000, FTView .... I have a problem with the analog outputs, I have...
1,901
Good day all. I would like to know if it is possible to change programming languages in RSLogix5000? For example, if a program is written using...
4,853
Is it possible to combine ladder and function block on RSLogix 5000? I can do ladder and FB but I have a code where analog and discrete signals...
2,904
My dear fellows... please help the needy guy who want to convert ladder code for start up routine to FBD using some automated tool. Please...
5,002
