Festo (Beck) FC20 Cable Pinout
shaunn
Sep 2005
Orapa
39
Hi All,
I have 2 Festo (Beck) FC20 small PLC's that look like they could be used for some kind of machine control. Very limited IO but still useful. I want to play with them and see what they can do, as I have the software disc that came with. However, I need a cable to connect them to my pc - DB9 to RJ11 by the looks of it.
Does anyone know the pinout of this cable? I have scoured the net but it doesn't look promising.
Any help will be greatly appreciated.
Thanks,
Shaun.
shaunn said:
Hi All,
Thanks,
Shaun.
Not sure if this helps (it may work, only if it is a DB9->RJ11 connector as you claim) but Automation Direct sells the cable for their own PLCs.
If you don't want to buy, you could find a pinout diagram on their site and make your own cable.
Not sure if it will work but can't see why not, only 4 pins to deal with on each side as the RJ11 can only use a max of 4 pins.
Hi. We've been asked to do an upgrade on plant, consisting on a PLC upgrade. This involves replacing a 1747-SDN module to a 1769-SDN, in a network...
61
Glad the site is working again... I have a customer having issues with a Festo and I have never worked with them, see below
1,337
Working with a Siemens PLC, I have to replace a bad Festo valve bank Profinet adapter with part number: CTEU-PN I am very comfortable with...
1,185
Hello Experts, Does anyone have this gsdml v2.31 festo cteu 20150503?? I've gone to the Festo website and the version that they have for cteu is...
816
Hello everyone, It's the first experience with a Festo's drives and the Festo Configuration Tool programming tool. Particularly with these...
1,527
